Ball Joint Dust Boot- Can it be replaced separately? - NCRS Discussion Boards
+ More Options
Posts
  • Mark E.
    • April 1, 1993
    • 4603
    The dust boot on my nearly new lower ball joint is torn.
    Can the boot be replaced separately? Or does the entire ball joint assembly need to be replaced?
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • 6950
    Re: Ball Joint Dust Boot- Can it be replaced separately?
    Mark Zip Corvette sells the correct ball joints for 35.00 each, not sure if the boots will work on originals. I have seen guys post here before looking for the lower boots with no luck.
    • Ron G.
      • December 1, 1984
      • 865
      "SOLID LIFTERS MATTER"
        • 43258
        Originally posted by Ron Goduti (8076)
        Mark,
        Itโ€™s my opinion that it cannot be replaced because of the manufacturing process. You will need to find another lower ball joint. - Ron
        Ron------
        I agree. The seals are attached to the body of the ball joint with a steel band-like retainer. I don't know of any way to remove it. Plus, even if it could be done, I know of no source for a replacement boot. GM never offered replacement boots for any 1965-82 Corvette ball joint.
        • Mark E.
          • April 1, 1993
          • 4603
          Thanks guys.
          Mark Edmondson
          Dallas, Texas
          Texas Chapter
