1970 heater hose clamps - NCRS Discussion Boards
  • Rick N.
    • August 25, 2017
    • 141
    According to the 5th edition judging guide the 3/4" heater hose uses 1 3/16" clamps not 1 1/4" like the 68-69 manual says.
    There a 4 clamps, The heater core to the expansion tank and from expansion tank to the water pump.
    Do all 4;locations use the 1 3/16" wittek DCM stamped clamps?
    I also need to verify that no 1 1/4" clamps are used for 1970
    Thanks, Rick
  • Allen N.
    • January 1, 2003
    • 288
    Re: 1970 heater hose clamps
    Rick,
    The 3/4" hose from the water pump to the heater box uses two 1 3/16" tower clamps with DCM on them and plated with DiChroMate.
    The 5/8" hose from the intake manifold to the heater box uses two 1 1/16" tower clamps with the date of the quarter on them.
    The hose from the expansion tank to the radiator uses two single screw type clamps.
    Allen
    • Rick N.
      • August 25, 2017
      • 141
      Originally posted by Allen Nichols (39120)
      Rick,
      Allen
      Hi Allen,
      Doesn't the 3/4" hose pass through the expansion tank requiring a total of 4 clamps?
      Thanks, Rick
      • Allen N.
        • January 1, 2003
        • 288
        Rick,
        You are correct. The 5/8" hose is connected to the expansion tank between the intake manifold and heater box, and it requires two 1 1/16" tower clamps with the quarter on them. In the AIM, you can see this on UPC 11/13, Sheet B6.
        Allen
