thermostat - NCRS Discussion Boards
thermostat
  • Mel S.
    • August 31, 1992
    • 264
    thermostat
    What is the degree for the thermostat that is used in 1970 350 LT1?
    • 43290
    Re: thermostat
    Mel------
    The original thermostat for the application mentioned was 195 degree. I recommend replacing with a 180 degree.
    • Mel S.
      • August 31, 1992
      • 264
      Re: thermostat
      That is what is in it.
      Thanls
        • 43290
        Re: thermostat
        Thanls
        Mel------
        Then someone replaced it previously, either on purpose or by mistake. All other 1970 Corvette engines were originally equipped with a 180 degree thermostat. The LT-1 was the exception. Why? Well, the LT-1 was the only 1970 Corvette engine that was equipped with the air injection reactor (AIR) exhaust emissions control system. GM always specified a 195 degree thermostat for AIR-equipped applications.
        • David S.
          • August 9, 2009
          • 595
          Re: thermostat
          I run this in my 70 LT1. Actually in all my cars. These are well worth the money.
          https://www.amazon.com/Milodon-16400.../dp/B000COO20I
          Best,
          Dave
            • 43290
            Re: thermostat
            Best,
            Dave
            Dave------
            This is the "Robertshaw"-type thermostat. I use and recommend this type, too. However, I use only a 180 degree version. Using a 160 degree can result in too wide a temperature swing. A corvette cooling system can usually not maintain a 160 degree temperature except in unusual conditions (e.g. very low ambient temperatures, long downhill grades, etc.).
