1970 350 water pump belt - NCRS Discussion Boards
  • Thomas B.
    • November 24, 2015
    • 26
    Hi
    I have a 1970 350 engine, no ps or ac and the original belt is too loose
    Water pump pully 3890419 CT
    Crank pully 3850838 BG
    correct belt should be gm 3941116
    What part numbers are correct to so i have a belt that fits?
    • 43222
    Re: 1970 350 water pump belt
    Originally posted by Thomas Borruso (61803)
    Hi
    Thomas------
    The GM #3941116 was a 3/8" X 35-1/8" belt. It was discontinued in 1975 and replaced by GM #9433723 which was a 7/16" X 35-1/2" belt. It was discontinued without supersession quite a few years ago. The 7/16" belt rides a little higher in the pulleys so it has to be a little longer to have equivalent fitment with the 3/8" belt. You should have no trouble finding a 7/16" X 35-1/2" belt in the aftermarket although a lot of these belts have gone metric now. Will it fit properly? That I do not know. But, if it does not, then your only option is going to be a Quanta reproduction belt and I've even heard of problems with those for this application. Unfortunately, since this belt has no adjustment it's got to be the EXACT length to fit properly.
    • Thomas B.
      • November 24, 2015
      • 26
      Joe:
      I have tried several different Quanta belts 3941116, hoping that one may be shorter.
      Can you confirm if the pulleys are correct?
      Water pump pulley 3890419 CT
      Crank pulley 3850838 BG
      Not sure what to do now, any suggestions?
      Thanks..
      Tom
        • 43222
        Joe:
        Thanks..
        Tom
        Tom------
        The pulleys you have are absolutely correct.
