C2 two hole straps in engine compartment - NCRS Discussion Boards
  • Randy R.
    • March 1, 1983
    • 477
    C2 questions:
    Is the orientation of the two hole straps on the inner fenders judged?
    Can either hole be used?
    Thank you,
    Randy
  • Leif A.
    • August 31, 1997
    • 3655
    Re: C2 two hole straps in engine compartment
    Randy,
    Which fender are you referring too? The passenger side fender has three holes to hold the overflow tank to radiator hose. The driver's side fender has four holes to hold the forward wiring harness from the firewall block to where it passes over the radiator support. And, I assume, you're asking about your '67.
    Leif
    • Randy R.
      • March 1, 1983
      • 477
      I am referring to my 67. My question refers to all of the two hole straps used in the engine compartment. The hole I am questioning refers to the holes in the straps.
      Thank you,
      Randy
      • Leif A.
        • August 31, 1997
        • 3655
        Randy,
        All of mine are in the hole closest to the middle of the strap. You want the harness or hose held snugly. Mine has been through judging a few times, and no mention of anything amiss.
        Leif
        • Gene M.
          • April 1, 1985
          • 4233
          Randy,
          If you are using the original straps one can tell the hole used as the pin side has flutes that leaves marks in the hole.
          • Michael A.
            • March 1, 1996
            • 508
            Mike Andresen
            Bloomington, IL
            • Leif A.
              • August 31, 1997
              • 3655
              Michael,
              That is the wire for the factory A/C.
              Leif
              • Michael A.
                • March 1, 1996
                • 508
                Mike Andresen
                Bloomington, IL
                • Leif A.
                  • August 31, 1997
                  • 3655
                  Better picture for you Michael.
                  Leif
