Help, I removed the floor mat an noticed it was damp. oily.. when I pushed down, the hole under the driver side, a oily substance came out. I also noticed lite oily feeling under the ash tray. any help would be appreciated.
71 Oil on Carpet
Re: 71 Oil on Carpet
Donald, Could it be DOT 3 Brake fluid? Check the interior boot area around your Master Cylinder. Maybe take a sample and apply it a scrap painted item to see if it removes the paint. If it does, it's DOT 3.
Rich- Top
Donald,
Have you checked carpet and backing for “oil” up under dash? Oil seep from gauge?
DaveJudging Chairman Mid-Way USA (Kansas) Chapter- Top
I just checked on a painted surface. no luck. it looks kinds greenish, but I am wondering if it is from the carpet which is royal blue.
I also opened the brake reservoir and it is almost full. with the amount of damp carpet, if it was brake fluid, it would be low.- Top
Donald,
From your description, oil is pooling at lowest point on floor. Any evidence on (under) carpet oil “wicked” from somewhere else - in particular from a source that also caused oil on ash tray?
Donald------I just checked on a painted surface. no luck. it looks kinds greenish, but I am wondering if it is from the carpet which is royal blue.
If it's actually "greenish" it could be engine coolant from a failed heater core. The location you describe would be unusual for that but if there's quite a bit of it, I'd say that's the most likely.In Appreciation of John Hinckley- Top
This makes sense, because before I took delivery from Vanguard, they had to replace the heater core.
how can i determine if it is the heater core.
Come to think of it, sometimes when the care is started, I hear a gargle sound.
it is also on the passenger side but not as much- Top
Donald, Check for traces of antifreeze in the heater ducts which point to the floor on both sides.This makes sense, because before I took delivery from Vanguard, they had to replace the heater core.
