battery source - NCRS Discussion Boards
battery source
  • Rick G.
    • March 1, 1983
    • 273
    Re: battery source
    Originally posted by Rick Aleshire (38392)
    Rick - tires if they are as you describe receive 3 point deduction which is not out of line
    Rick,
    Thank you for your response. Are you saying the total deduction is 3 points or is this per tire?
    Rick
    • Rick A.
      • July 31, 2002
      • 2147
      Re: battery source
      Rick for tires there is a standard deduction for tires on the ground of 3 points total, again provided they are like you suggest we should be judging against.
      Rick Aleshire
      2016 Ebony C7R Z06 "ROSA"
      • John D.
        • December 1, 1979
        • 5507
        #18
        Re: battery source
        I don't typically talk about judging or get involved. I am the food guy of our chapter.
        We are judging the cars the way they came down the St. Louis assembly line. So if you don't have the right parts a deduction is "earned".
        JD
        • Harry S.
          • July 31, 2002
          • 5294
          #19
          Re: battery source
          If you have a real spare it's a 2 point deduction. Each tire is worth 6 points or a total of 30 points ( five tires ). If you have a real spare then it's 4 * 6 = 24 then a 10% deduction = 2.4, then you round down to a 2 point deduction.
          • James W.
            • December 1, 1990
            • 2654
            #20
            Re: battery source
            I would like to see the repro and currentOEM "Delco" group 24 maintenance free battery get a little more leniencyin the std. deduction guide.
            I do drive my cars to the NCRS events and have them judged. Knowing that thebattery is going to work when needed eases my anxiety when leaving on a longtrip. Saying that, I know that even the current maintenance free batteries canfail. I've been using them for years with no problems even the recent ones I'veinstalled, not so for the repro battery that I bought in 2014. As fortires, I have the correct original spares in both of my C2 cars. I run thecorrect size/side wall OEM radial and take the points deduction which I am finewith.
            James
