Knob type Battery disconnect device - NCRS Discussion Boards
  • Frank D.
    • December 27, 2007
    • 2703
    Re: Knob type Battery disconnect device
    Originally posted by Harry Sadlock (38513)
    I've had two of them fail. This is what I now use.
    http://www.sears.com/wirthco-enginee...8&blockType=G8
    I ONLY use the knife switch now - after several failures with the knob type - not cheap ones either.
    Over time I found it took more and more cranking on the knob to get a good connection until finally it was no longer a sure thing at all...
    • Steven B.
      • April 11, 2012
      • 233
      Originally posted by Joe Ray (1011)
      It is not made to remove from the terminal and put in your pocket! Duh!
      JR
      Guess I don't know what the "Duh!" is about because those advertising their products are touting "can also be completely removed to deter theft". Not create a theft proof condition, just discourage. I don't recollect ever having completely removed the knob on mine. As I said before, if someone is determined enough, they will most likely find a way to steal things.
      Steve
      • Leif A.
        • August 31, 1997
        • 3646
        #18
        Steve
        Steve,
        The knob itself is removable "as advertised".
        Leif
        • Tim G.
          • March 1, 1990
          • 1392
          #19
          I've bought cheap knob disconnect switches at car shows and they don't cut off all the time. Now I just pay for the ones from Restoration Battery, they work fine.
          • Edward B.
            • January 1, 1988
            • 537
            #20
            If you want your car to look like a 1920's electrical plant buy a knife type switch. For something more modern try: https://www.summitracing.com/parts/h...srese2-_-hella
            The red lever is removable just like your green knob and there are many mounting locations available so the switch will not be visible to a casual observer:
