Adding Power Steering to a C2 Top Flight Car - NCRS Discussion Boards
  • Darryl D.
    • February 7, 2017
    • 386
    #46
    Re: Adding Power Steering to a C2 Top Flight Car
    There is no build sheet for a 66 and even with a 67 that had a tank sticker that would show how the car was equipped from the factory and even with a 67 up there is no requirement to provide one. This being said if PS is added with all the correct items and it was available for your car there is no way to determine if it had it or not. There should be no deduction for it even if your car was judged previously without it. No one can say either way if it had it previously, was removed and then re-installed.
    • Dan A.
      • May 31, 1974
      • 1074
      #47
      Not entirely, there are 2 engine codes in '66 that specifically call out power steering as an option.
      • Michael J.
        • January 27, 2009
        • 7119
        #48
        But not an L36........
        • Gene M.
          • April 1, 1985
          • 4232
          #49
          But the car in topic according to the poster is a small block L79. Only if the car had ac the code HP or KH would be in the build code. But if no ac then no code depicting power steering.
          • Dick W.
            • 10483
            #50
            Originally posted by Brian McHale (28809)
            I thought prior knowledge was out the window.
            Seems that some have forgotten that Brian. "As presented" is the key term. "Undetectable" is another, no matter what someone things
            Dick Whittington
