checking tri power end carb diaphrams - NCRS Discussion Boards
+ More Options
Posts
  • Mark G.
    • January 31, 2007
    • 177
    Should the end carb diaphragms hold vacuum when checking with a Mityvac? i checked my 5 end carbs I have and none hold vacuum. Is there any way to determine if they work or not come short of driving the car? Thanks.
    Mark
  • Timothy B.
    • April 30, 1983
    • 5202
    Re: checking tri power end carb diaphrams
    Mark,
    I don't believe you can check them like that, check if there is a air bleed hole in the secondary venturi. if it's like a regular vacuum secondary carburetor this hole is connected to the vacuum passage going to the diaphragm. If it's there plug it with putty or your finger then pull a vacuum on the diaphragm.
    • Chris H.
      • April 1, 2000
      • 837
      Timothy is correct.....use your pinky to block the vent then use your mityvac to check operation.
