Question On 1968 Engine Eye Lifts(Brackets)>L36 Vs L68's - NCRS Discussion Boards
  • Larry E.
    • 1692
    Still working on my Man Cave L36 display engine.(Picture Below) AFAIK the front (Drivers Side)
    double hole pull was taken off at St.Louis on the L68's(Due to fuel line)-Question>Was it left on
    L36 engines? On the back the judging manual indicates the single hole lift bracket was attached
    to the head. (I have seen some attached to the back intake manifold;probably not correct)
    Question>Was this left on both L36's and L68's? Thanks in advance--Larry
    Larry
    LT1 in a 1LE -- One of 134
  • Gary B.
    • July 31, 1979
    • 926
    Re: Question On 1968 Engine Eye Lifts(Brackets)>L36 Vs L68's
    My opinion, yes the L36 used a front lift bracket off the LH front two intake manifold bolts. Fig. M 7.8 in the 5th Edition 68-69 TIM&JG shows the bracket.
    Also my opinion, I believe both L36 and L68 also had the rear lift eye.
    I'll be looking at a couple very original 68 tri-power cars tomorrow. I'll double check they have the rear lift bracket, but pretty sure they do.
    Gary B
    • Richard T.
      • February 1, 1979
      • 858
      I own a low mileage (37 K ) two owner 68 with an L-36 and both the front and rear brackets. Also the rear is attached to the passenger side head, difficult to see. Rich
      • Larry E.
        • 1692
        Thanks Gary and Richard for the responses. On the back eye pull need to know if it is just a straight rectangle
        or is it a rectangle with a 90 Degree bend in it. If it does have a bent is the bent facing the bottom of the engine
        or the side the the engine? Thanks again. Larry
        Larry
        • Gary B.
          • July 31, 1979
          • 926
          It is just a straight rectangle. Bolts on the upper, inner bolt, closest to the intake.
          Gary B
          • Richard T.
            • February 1, 1979
            • 858
            Mine is also straight
