1972 LT-1 CEC Solenoid - NCRS Discussion Boards
  • Jack C.
    • September 30, 1992
    • 1090
    My 72 LT-1 is missing the CEC Solenoid. The electrical plug is intact. I would like to replace the solenoid. Since the vacuum line(s) were replaced, is there any issue with me replacing the solenoid and hooking up the vacuum hose according to factory spec's?
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
    • 11666
    Re: 1972 LT-1 CEC Solenoid
    1971 is CEC, 70 and 72 are TCS.
    Go ahead and replace it. They make them in reproduction now, so not difficult to source them and get the system back to specs.
    I often bypass the solenoid and run full-time vacuum on my own 72, but there's no harm to running the factory configuration.
    • Jack C.
      • 1090
      Thanks Patrick!
      Jack Corso
      • Ed D.
        • December 1, 1990
        • 329
        Jack,
        Make sure the transmission switch and the relay in the dash is working. The temp sender in the passenger side head probably wont stop it from working at normal temp. Good luck with the new car. I have an original solenoid if you need it
        Ed
        Ed DiNapoli
        CNJ Chapter Past Chairman/Co Founder
        1972 Targa Blue Coupe, Original Owner,
        Duntov Award, Sam Foltz Award,
        Founders Award, NCRS Gallery VIII
        2011 Corvette Convertible
        NCRS Presidents Award 2014
        • Gary J.
          • April 1, 1980
          • 1244
            • 11666
            I believe that Lectric Limited has them made. I would not be surprised if others also sell them.
            This may be it:
            Or, search for 1114451 on eBay.
            • Jack C.
              • 1090
              Originally posted by Ed DiNapoli (18386)
              Jack,
              Ed
              Thanks Ed. Good to be back home again.
              Jack Corso
              • Jack C.
                • 1090
                Paragon has them and also ebay.
                Jack Corso
