My 72 LT-1 is missing the CEC Solenoid. The electrical plug is intact. I would like to replace the solenoid. Since the vacuum line(s) were replaced, is there any issue with me replacing the solenoid and hooking up the vacuum hose according to factory spec's?
1972 LT-1 CEC Solenoid
Re: 1972 LT-1 CEC Solenoid
1971 is CEC, 70 and 72 are TCS.
Go ahead and replace it. They make them in reproduction now, so not difficult to source them and get the system back to specs.
I often bypass the solenoid and run full-time vacuum on my own 72, but there's no harm to running the factory configuration.Vice-Chairman (West), Michigan Chapter NCRS
I often bypass the solenoid and run full-time vacuum on my own 72, but there's no harm to running the factory configuration.Jack Corso
1972 Elkhart Green LT-1 Coupe 43,200 miles
Top Flight 1994, 2018 & 2021- Top
Jack,
Make sure the transmission switch and the relay in the dash is working. The temp sender in the passenger side head probably wont stop it from working at normal temp. Good luck with the new car. I have an original solenoid if you need it
EdEd DiNapoli
CNJ Chapter Past Chairman/Co Founder
1972 Targa Blue Coupe, Original Owner,
Duntov Award, Sam Foltz Award,
Founders Award, NCRS Gallery VIII
2011 Corvette Convertible
NCRS Presidents Award 2014- Top
Thanks Ed. Good to be back home again.Jack Corso
