65 A.O. Smith job number behind dash - NCRS Discussion Boards
  • Keith B.
    • September 15, 2014
    • 1604
    what do you make of this number behind the dash cluster on the cross brace
    this is on the bulk head and the same number is else where on the car
  • Donald S.
    • August 31, 1996
    • 186
    Re: 65 A.O. Smith job number behind dash
    [QUOTE=Keith Brodbeck (60464);821362]what do you make of this number behind the dash cluster on the cross brace
    My recollection is that this is your key code...it should match the number on the key knock offs and on the body of the ignition cylinder.
    Don
    • Gene M.
      • April 1, 1985
      • 4233
      Body build a three digit number.
      • Keith B.
        • 1604
        Gene the job number is I 445. I think Donald is on to something about key code
        • Gene M.
          • April 1, 1985
          • 4233
          Keith, did you check to see if the key # aligns with this #?
          If you look farther down the frame under the dash towards the glove box there is a built # . This is the one iโ€™m Referring too.
          The โ€œkeyโ€ number is not common to find marked on this frame member. Neat find if it is indeed the key #.
          • Keith B.
            • 1604
            This car is at my dads garage and I called and asked him to look at the key code. Hasnโ€™t called me back. Iโ€™ll have to look further for more numbers I was pressed for time. I havenโ€™t took enough of these cars apart to see all these little difference
            • Stewart L.
              • March 1, 1980
              • 356
              • Joseph S.
                National Judging Chairman
                • March 1, 1985
                • 944
                Keith, It is definitely the Key Code number. I've seen it many times (too many to count). As long as your locks have not been changed, this will match what is stamped on them.
                • Keith B.
                  • 1604
                  you guys where spot on. So now you know the key code please don't steel the car when its done
                  • Don H.
                    Moderator
                    • June 16, 2009
                    • 2288
                    key already made, watch for drone over your garage
                    • Keith B.
                      • 1604
                      I like target practice!
                      • Paul S.
                        • June 30, 1982
                        • 359
                        THIS IS ON A AN EARLY 1966
