1957 Distributer hold down - NCRS Discussion Boards
  • Dan P.
    • December 1, 1990
    • 683
    Did the distributor hold down bolt have a lock washer . AM does not show one . Could that be because it was made on the bolt.
  • John D.
    • December 1, 1979
    • 5507
    Re: 1957 Distributer hold down
    Dan, No washer. Yes the bottom of the bolt does have a flat are-like you said.
    Same as the original 8 nuts that hold the 57-65 fuel injections onto the baseplate (intake). No washers as the nuts had a slightly raised area like a flat washers. Just had 5 in my hand a little while ago. Going to put an original set on my '63. John
      • 43219
      Dan------
      It was not a flanged head bolt, if that's what you mean. However, I recommend using a flanged head bolt.
