454 water pump heater hose outlet - NCRS Discussion Boards
  • Howard H.
    • January 10, 2007
    • 139
    The various corvette parts suppliers show a relatively long heater hose water pump fitting for a 70 454 with a/c. With the heater hoses going over the top of the compressor, is there enough clearance for the hose to come over and down and connect up without kinking the 3/4 inch hose? I looked at a 71 454, a/c car and it had a short fitting. Don't know if it is original. Any thoughts would be appreciated.
    • 43222
    Re: 454 water pump heater hose outlet
    Howard-----
    1970 with LS-5 and C-60 used a short heater hose nipple in the waterpump. It was GM #3739798.
    • Leif A.
      • August 31, 1997
      • 3633
      Howard,
      See if this works for you...
      https://www.corvettecentral.com/c3-6...3%26count%3d45
      Leif
        • 43222
        Originally posted by Leif Anderson (29632)
        Howard,
        Leif-----
        That's not the correct nipple for LS-5 with C-60
        • Jack M.
          • March 1, 1991
          • 1163
          Found an older post from Joe (with a picture): CLICK HERE
          • Keith K.
            • January 23, 2008
            • 510
            It is a shorter nipple - here is a pic from my 74 - the hose doesn't really go over the compressor on this car.
            r
