Manual steering box lube - NCRS Discussion Boards
  • Danny P.
    • Today
    67 Corvette just rebuild my Manual box, lube with Grease or 90w oil don,t want it to leak
  • Danny P.
    • Today
    Re: Manual steering box lube
    please delete this post
      • 15706
      GM used to sell a tube of special grease, I think 10 oz., that was specifically for the Corvette steering gear. It's long discontinued so use a synthetic NGLI #2 grease like Mobil One and pack the housing to near full.
      Synthetics base oils have lower vapor pressure and are more resistant to oxidation than conventional base oils, and since the steering gear is close to the exhaust manifolds it runs hotter than on pass. cars, so you need high oxidation resistant base oils in the grease, and the lower vapor pressure means it won't "dry out" as fast.
      P. S. you can delete your post by using the edit function.
      • Danny P.
        • Today
        Yes i wasnt sure , if it was 90w oil grade oil or just grease, thanks for getting back Duke
        • Gary B.
          • July 31, 1979
          • 926
          Penrite makes a 1200w oil. Comes in a small bottle.
          Gary B
          • Gary R.
            • April 1, 1989
            • 1799
            Danny if you use gear oil it will leak, new seals or old. Mobil 1 separates badly and will also leach out red oil- I stopped using it years ago because of that problem. I use Lucas green grease now in boxes and haven't had any issues with it.
            • Danny P.
              • Today
              Thanks Gary , that what i need
