1978 Corvette Owners Manual - NCRS Discussion Boards
  • Larry C.
    • April 1, 1980
    • 279
    Re: 1978 Corvette Owners Manual
    FWIW, as the original owner of #30457, build date 6-13-78, the back of the owner's manual indicates part # 460294B.
    Larry
    • David K.
      • September 30, 1979
      • 241
      the NCRS store has one
      • Ralph S.
        • February 1, 1985
        • 935
        #18
        This complete set has a 460294 A The Corvette news postcard section that you mail in has 1977 in the lower right corner
        • Dave S.
          • August 31, 1992
          • 2926
          #19
          Thats cool Ralph. Thanks for posting
          Now the obvious question......Do you recall where it came from? If it was from an early VIN car then that my answer the question at hand.
          • Ralph S.
            • February 1, 1985
            • 935
            #20
            I am sure it came from an early car
            • Barry L.
              • January 1, 1998
              • 119
              #21
              Okay gentleman I done a little research to clarify some of the mystery as to why there is a A manual and a B manual. I had an A manual already so I purchased a B manual to compare. After reading through both manuals I did find some differences. In section 2, page 27, 2-27 I found that manual A has a picture demonstrating how to release the T-Top hold down strap. Then under the photo it gives instructions about the Anti-Theft Alarm System. In manual B 2-27 it has the same picture demonstrating how to release the T-Top hold down strap. However, under that photo in manual B it has CAUTION and gives instructions about strapping down the T-Tops in case of an accident. Then followed by NOTICE: If equipped with the optional GLASS T-Tops... Then it goes into the Anti-Theft Alarm System.
              Now move on to section 5, page 8, 5-8 Manual A Starts out with a sub heading Manual Transmission Lubricant, then another sub heading Manual Transmission, followed by Transmission Shift Linkage (Manual and Automatic), followed by Clutch Cross-Shaft, then Clutch, then Clutch Fork and Ball Stud, then Clutch Linkage. Then a Main heading ENGINE COOLING SYSTEM, then followed on the next page, page 9, a diagram showing how to adjust the clutch assembly for a manual transmission. Then there is a continuation of giving details of the engine cooling system. then followed by a sub heading Cooling System Care.
              Now in manual B page 8 starts out with a sub heading Manual transmission Lubricant, but the following sub heading Manual Transmission is omitted. Then the page continues the same as manual A with Transmission Shift Linkage (Manual and Automatic), Clutch Cross-Shaft. As page 8 continues it is different than manual A as it has a main heading, CLUTCH ADJUSTMENT-MANUAL TRANSMISSION. This section gives instructions on how to adjust the clutch assembly followed by the diagram. Then on page 9 the sub heading Clutch, Clutch Fork and Ball Stud and Clutch Linkage. Then the main heading ENGINE COOLING SYSTEM. It seems that in the manual B, Helms got instructions a little more organized. So I interpret the 1978 Corvette owners manuals as having a First Edition and a Second Edition. I don't know how this would effect the judging for having the right contents in the glove box according to VIN number.
              • Dave S.
                • August 31, 1992
                • 2926
                #22
                Nice work Barry. I'm sure Tom Russo and the rest of the 78 re-write team appreciate it. I learned something too.
                • Reba W.
                  • 938
                  #23
                  I second Dave's comment on your research, Barry. The revision team will appreciate this. This confirms the fact that whether it uses a letter or month/year designation, a second manual is issued because of changing information.
                  • Barry L.
                    • January 1, 1998
                    • 119
                    #24
                    Miss Reba I apologize. I should have said Ladies and gentleman. I was not thinking at 11:19 PM. But I do appreciate your response. Hope you all had a good Christmas and have a safe New Year.
