53-55 Pinion Seal and Bearing sources - NCRS Discussion Boards
  • Gary R.
    • April 1, 1989
    • 1798
    Re: 53-55 Pinion Seal and Bearing sources
    Thanks Mike
    • Troy P.
      • February 1, 1989
      • 1284
      Unfortunately SKF did screw up the interchange with the GM number. Their 17727 seal is actually the 56-62 seal, not 53-55.
      So back to square one. Where can we get them at non-Corvette prices?
      BTW, Zip advertises a 53-62 differential rebuild kit at a very reasonable price. But of course it does not fit 53-55 as advertised. Beware.
      • Gary R.
        • April 1, 1989
        • 1798
        #18
        Troy
        While I don't work on those diff's I have been telling guys for years the kits sold for 63-79's don't have the correct case shims in them for 63-66's. Yet they are sold everyday.
        • Chris S.
          • January 1, 2000
          • 1068
          #19
          I used a Citation diff seal - I learned this trick from Jack Kerklias
          I will look up the part number
          1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
          Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
          1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
          1957 Corvette - FI 3 sp - Black and Silver
          • Troy P.
            • February 1, 1989
            • 1284
            #20
            Forgetting GM and interchange part numbers, which were not working, I searched SKF catalog by size. Recall the 55 Corvette P&A says the sizes are 1 7/8" ID by 3 7/16" OD.
            I found an SKF 18926 that is very, very close - $24.25 from Grainger. 1 7/8" by 3 1/2", only 1/16" off in the bore diameter. I wonder if it would work.
            • Jim L.
              • September 30, 1979
              • 1808
              #21
              Not a chance. No way would you ever be able to shove a 3-1/2" OD seal into a 3-7/16 ID hole in the differential carrier.
              Nice try, though.
              Jim
