Rear Leaf Spring, 1964, Regular Suspension - NCRS Discussion Boards
  • James C.
    • July 4, 2012
    • 81
    Need some advice/help. Detailing the rear suspension and need to replace the rear leaf(9).
    Question, better to go original or reproduction? Found a "new" spring from Corvette Stop
    Restoration Services out of California. Thanks for the advice/support.
    Jim
  • Don H.
    • December 1, 1981
    • 1501
    Re: Rear Leaf Spring, 1964, Regular Suspension
    Jim,
    It depends on if you plan to have the car judged. The current new springs work great but will take a deduction if judged. (I painted my new spring the correct color before I installed it a few years ago.)
    Good luck,
    Don H.
    • Gary B.
      • February 1, 1997
      • 7082
      Jim,
      America's Finest Corvettes in California makes a repro 9-leaf spring that supposedly will not garner a deduct. The downside is the price.
      Gary
      • Ed S.
        • August 6, 2014
        • 1390
        Jim,
        I replaced the main spring on my 64 (standard suspension) - I got the single 9th main spring from Eaton. Not cheap but aesthetically it is a perfect match to an original, angle of end cuts and all. I had my 8 other leafs sand blasted and then painted them. I purchased a "restoration kit from Quanta - their liners are nice and appear to be the correct length. I also got the "grey" paint from Quanta. End cups for the spring is another whole story. I have to do some records research to recall where I got mine. PM me or call if you want to discuss this farther.
        Ed
        Ed
          • 15706
          Jim
          Why do you think you need to replace it?
          • James C.
            • July 4, 2012
            • 81
            Duke, the current spring is a newer unit w/out the flaring up so to speak at the ends.
            I am trying to get anything not original to factory repaired/replaced.
            Jim
