65-66 Big Block Spark Plug Heat Shields-What is correct? - NCRS Discussion Boards
  • Ronald L.
    • October 18, 2009
    • 3248
    Re: 65-66 Big Block Spark Plug Heat Shields-What is correct?
    Mike - what is the Build date of your car? You may not need the shields if it is late 66 car...
    Note the other thread started here by Michael Hanson that talks about the deletion of these shields.
    More On 65-66 BB Spark Plug Heat Shields
    By Michael Hanson (4067) in forum Technical Discussion Archives
    To that extent I know I have mine original to the car, and that being April 29, 1966.
    • James W.
      • December 1, 1990
      • 2655
      Mike,
      Attached are pictures of 1965 396 spark plug heat shield as installed on an NCRS Duntov/Bowtie car with 26K mikes, VIN 1764x and a 1965 396 BG Survivor. Notice the welded seam at the very bottom of the shield that runs the entire length. The '65 396 car that I restored VIN 2216x had the same heat shields on it when the car was purchased in unrestored condition in 2002. The car has been through all level of flight judging as recent as 2014 with no deductions on the heat shields. As Gen Manno mentioned have them zinc plated and you will be good to go.
      Hope this helps.
      James West
