My 1967 survived Irma but the fuse block now has rusty fuse connectors and the tail but the tail lights still don't work. It is a tad loose on the hot side. Is there any quick fixes to this problem. The car still has the original dash harness and a replacement engine harness. Thanks Bill
Rusty fuse block
Tags: None
- Top
Re: Rusty fuse block
I assume your car was under water at some point to get the rusty connectors. I'd recommend removing ALL the wiring and inspecting the connections for corrosion. As a minimum I'd bead blast all the terminals of the entire wiring harness. The fuse block may need to be replaced if the rust is heavy, especially on the "wire" side- Top
Bill, I recommend a product call DeoxIT D5. Comes in a small spray can, available at Radio Shack and other electronic retailers.My 1967 survived Irma but the fuse block now has rusty fuse connectors and the tail but the tail lights still don't work. It is a tad loose on the hot side. Is there any quick fixes to this problem. The car still has the original dash harness and a replacement engine harness. Thanks Bill
Dissolves Corrosion
Improves Connections
Protects Surfaces
I have used this product with good results on rusty fuse boxes in the past.
Good Luck !!
John1973 L82 M21 4 Speed, very original and well documented driver/survivor
NW Chapter Member, 2016 Bend Regional Top Flight
73/74 TIM&JG 3rd Edition Revision Team Member- Top
