1955 headlamps on ebay - NCRS Discussion Boards
  • Ronald R.
    • May 31, 1989
    • 670
    http://www.ebay.com/itm/NOS-1955-CHEVROLET-CAMEO-ALL-TRUCKS-HEADLAMP-UNIT/292265964840?_trkparms=aid%3D111001%26algo%3DREC.S EED%26ao%3D1%26asc%3D20160727114228%26meid%3Dee551 b3975d84823804d70050708066d%26pid%3D100290%26rk%3D 1%26rkt%3D4%26sd%3D292265964840&_trksid=p2060778.c 100290.m3507
    https://www.ebay.com/itm/NOS-1955-CH...19.m1438.l2649
  • Jeffrey S.
    • May 31, 1988
    • 1882
    Re: 1955 headlamps on ebay
    Ronald,
    At the bottom of the lens it says "Auto Lite" not Guide. Was AutoLite a supplier of bulbs to the Guide division?
    Jeff
    • Ronald R.
      • May 31, 1989
      • 670
      No, I could not read that just saw the 12V in the center, lights are from different places
      sorry RDR
      • Ronald R.
        • May 31, 1989
        • 670
        check the second photo I believe it is Guide
        • Jeffrey S.
          • May 31, 1988
          • 1882
          Yep, it is.
          • Dan A.
            • May 31, 1974
            • 1074
            Ron if you go to the Michigan chapter web site http://www.michiganncrs.org/ and click on videos or the link below you will be able to see an actual '53-4 and very early '55 only steel back sealed beam. Jeff presented an excellant seminar on headlight bulbs and sealed beams.
            or on YouTube
            • Ronald R.
              • May 31, 1989
              • 670
              It was usefull info but he skipped from the 12 volt steel back strait to the T3's. There is a big gap here!
              thanks RDR
              • Jeffrey S.
                • May 31, 1988
                • 1882
                thanks RDR
                Ronald,
                You are correct that I skipped the glass 12 volt bulbs used in 1955. I had no examples to show and I neglected to even mention them. It was an oversight. If I ever have to repeat the presentation I will add them.
                Jeff
                • Ronald R.
                  • May 31, 1989
                  • 670
                  here are some pictures, if you give me an address I'll send a light that has a vacuum leak if you want thanks RDR
                  • Jeffrey S.
                    • May 31, 1988
                    • 1882
                    Email sent.
                    Jeff
                    • John S.
                      • July 29, 2009
                      • 640
                      Which headlight would not have originally been on a 55 corvette?
                      • Ronald R.
                        • May 31, 1989
                        • 670
                        this one
                        • John S.
                          • July 29, 2009
                          • 640
                          Ron, I just noticed that this is not a Guide headlight. It's a AutoLite so it would not originally been on a 55 Corvette. The two I posted were Guide headlights.
                          • Troy P.
                            • February 1, 1989
                            • 1284
                            A couple of years ago I wrote an extensive article in the Restorer covering all the versions of the 53-55 headlight bulbs. There were 4 different 12V units. Two steelback and two all glass. (The first 12V steelback came out in 53 and was not used in Corvettes.) Then came the T-3, which included a 6V T-3 as well as the commonly seen 12V.
                            • Jeffrey S.
                              • May 31, 1988
                              • 1882
                              Troy,
                              Can you post the date the article was published?
                              Jeff
