Painting 1969 Convertible - NCRS Discussion Boards
  • Steve M.
    • January 1, 2006
    • 258
    Ready to paint my car, finally. I have decided to go with the following PPG Products: DPLF, K36, DPLF and DDL in Riverside Gold. The body has been stripped with stripper down to the 'red oxide primer' and then to bare fiberglass with green scotch pads and water last summer. My questions are what to wipe the bare body down with before DPLF application ? Some have suggested acetone on the bare fiberglass? Some of the cleaners from PPG do not recommend their products on fiberglass? What to use to wipe down the DPLF if anything before the application of K36 ? After blocking the K36, what to wipe down before the final DPLF ? After all the work involved to get to this point, hate to mess-up now. Any comments or recommendations would be greatly appreciated?
    Steve
    • 15616
    Re: Painting 1969 Convertible
    Steve
    And you had your version of Riverside Gold matched to a known original example?
    • Bob W.
      • December 1, 1977
      • 802
      Steve Have you spoken to anyone from PPG ? If not I think that is where I would start.
      • Steve M.
        • January 1, 2006
        • 258
        Thanks for responses. Paint matched to the original hard top that had never been painted. Will discuss with PPG but was hoping to receive some actual Corvette experiences since these products have been mentioned in the Forum. Steve
        • Bob W.
          • December 1, 1977
          • 802
          Steve I would call PPG if something goes wrong this what they told you to do.
          Bob
          • Paul O.
            • August 31, 1990
            • 1716
            Steve
            Contact John Ballard for guidance for painting your car he is your best resource. On product and formulas. 502-905-3942
            • Dick W.
              • 10483
              Steve
              DPLF will seal the fiberglass. I would not worry about a prep wash penetrating the DPLF and the K36. It is almost an impervious substrate
              You are on the right track for the substrates. If I was painting another car that would be my choice of materials. The DPLF seals the fiberglass, the K36 is a heavy build primer/surfacer, and the DPLF is a wonderful sealer to use under your top coat, whether it be lacquer, single stage, two stage, waterborn or whatever
              Dick Whittington
              • Steve M.
                • January 1, 2006
                • 258
                Dick, appreciate the conformation on the choice of substrate products. Thanks Steve
                • Paul O.
                  • August 31, 1990
                  • 1716
                  Steve
                  Have you talked to John Ballard he has helped many NCRS members with their painting projects. He has been in the paint business for more then 50 years. 502-905-3942
                  Paul
