Cigarette Lighter Lamp - NCRS Discussion Boards
  • Gene K.
    • August 31, 2006
    • 34
    My 1963 Casco lighter has no lamp fixture, bulb or separate wiring associated with a lighting function.
    Questions: #1 Do all lighters in 1963 have a lamp function?
    #2 Is there a separate harness for the lamp or is the lamp powered by the lighter wire?
    #3 Does the lighter housing bulb shade mount on the female lighter housing?
    Thanks for your help,
    Gene
  • Peter H.
    • April 1, 1980
    • 225
    Re: Cigarette Lighter Lamp
    Gene the outer housing should have cut out and two slots on each side for the hooded light socket to clip into . The socket shoud be on a grey single wire .hope this helps you...peter ..another 63 owner.
    • Gene K.
      • August 31, 2006
      • 34
      Got it, Thanks so much!
      • Gene K.
        • August 31, 2006
        • 34
        Hello again, When I try to purchase a wire with spring bulb holder that fits the shield, all venders only sell one that goes up to 1962. What do you recommend? I appreciate your help. Gene
        • Harry S.
          • July 31, 2002
          • 5302
          Gene, the wire to the bulb is part of the wiring harness. If it's not hanging there loose then someone may have cut it off. See if you can find a spot in the harness where electrical tape has been added. If so remove the tape and look for the wire. You can get the socket and probably the wire off an old harness at a swap meet. The original harness wrapping has no adhesive on it so it's easy to spot the electrical tape.
          Someone must have a picture with the cluster out that shows the wire. I looked I don't have one.
          • Gene K.
            • August 31, 2006
            • 34
            Now, I finally understand what's going on with this. I have been obsessing over this problem for a while. Appreciate your help.
            Gene
            • Stewart L.
              • March 1, 1980
              • 354
              Gene you didn't waste much time getting back to work after Redmond! I sent you a photo of some bulb wires off a 63 harness I have for parts, you can have what you need.
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11323
                Edit... I got this totally wrong. Sorry, my brain was thinking IGN switch. I'll just leave it here. But I think the Lighter Lamp socket can be seen to the right of the IGN lamp bracket below, so maybe it'll help a little anyway.
                The 1963 in unique. The lamp bracket and wire is part of the Main Harness. It is attached to the Cluster with a screw. Shown below at a bad angle(between the R and K or the PARKING BRAKE handle).
                This is the only shot I have of a lamp, from another source, which someone cut and added a terminal.
                Last edited by Richard M.; September 17, 2017, 08:15 AM. Reason: error where located
                • Richard M.
                  Super Moderator
                  • August 31, 1988
                  • 11323
                  To possibly redeem my error, here's a shot of a '67 Lighter assembly which may help.
                  • Mike D.
                    • July 31, 1996
                    • 306
                    Gene, thanks for bringing your car to Redmond. It is very nice. Glad the members could give you pictures to help with your lighter lamp. I am seeing a higher score on your swc next time.
                    Mike Doty
                    Intermountain Chapter Judging Chairman
                    Region VIII Director
                    • Gene K.
                      • August 31, 2006
                      • 34
                      Great photos
                      Very helpful. I appreciate your response
                      Gene
                      • Brad V.
                        • May 2, 2015
                        • 30
                        I know this has been asked and answered, but just came across this doc which has the lighter harness / connector as well as everything else from the Mid-Atlantic Chapter NCRS
                        • Gene K.
                          • August 31, 2006
                          • 34
                          This is an amazing document. Its useful in so many areas.
                          Gene
                          • Peter H.
                            • April 1, 1980
                            • 225
                            Hello gene..sorrry i have been away for a couple of days .. If memory serves me that same lighter socket is in a full size chevrolet..same set up..peter ...
