Who makes and or sells the closest reproduction fuel pump for a 20xxx serial number 1965 396 ?? How close is a 40082 for a 1967 ??
1965 396 Fuel Pump
Re: 1965 396 Fuel Pump
Jimmy, I purchased p/n 352075 from Corvette Central in 2014 for my L78. All fuel lines are stock and all bolted to new pump w/o any issues. Car is driven couple of time a week and it was working great this morning. It looked just like the pump I removed, which I doubt was an original. I have no idea if it will pass flight judging (if it is a judged component). Regards ---- Top
Zip shows new pumps for $279.99
Also had this note;
New OE-style 1965 Late 396 - 1966 427 Corvette fuel pump with "AC" casting as original. Correct steel crimp design includes original GM part number 40366 stamped in casting. Note: 1965-1966E 396/427 fuel pumps use a round lower fitting. Late 1966 427 Corvette pumps use a square lower fitting. Early pumps were used until approximately 01/1966.
No idea if they will pass judging.- Top
In my picture archives I could only find one picture of a fuel pump on a unrestored '65 396 Bow Tie car, serial #17,64x that was on display at the 2008 National Convention.
JamesAttached Files- Top
