1965 396 Fuel Pump - NCRS Discussion Boards
1965 396 Fuel Pump
  • Jimmy G.
    • November 1, 1979
    • 976
    1965 396 Fuel Pump
    Who makes and or sells the closest reproduction fuel pump for a 20xxx serial number 1965 396 ?? How close is a 40082 for a 1967 ??
  • Carl N.
    • April 30, 1984
    • 592
    Re: 1965 396 Fuel Pump
    Jimmy, I purchased p/n 352075 from Corvette Central in 2014 for my L78. All fuel lines are stock and all bolted to new pump w/o any issues. Car is driven couple of time a week and it was working great this morning. It looked just like the pump I removed, which I doubt was an original. I have no idea if it will pass flight judging (if it is a judged component). Regards ---
    • James W.
      • December 1, 1990
      • 2657
      Jimmy,
      I used a fuel pump bought from Goat Hill on the '65 396 when I restored it. Went through all levels of flight judging with no deductions. The car is VIN #2216x.
      James West
      • Stewart L.
        • March 1, 1980
        • 354
        Does anyone rebuild an original fuel pump for a 396?
        • Bob K.
          • September 28, 2011
          • 36
          Call Claude Phillips at 618 842-3948. He may be able to help.
          • Richard G.
            • July 31, 1984
            • 1715
            Zip shows new pumps for $279.99
            Also had this note;
            New OE-style 1965 Late 396 - 1966 427 Corvette fuel pump with "AC" casting as original. Correct steel crimp design includes original GM part number 40366 stamped in casting. Note: 1965-1966E 396/427 fuel pumps use a round lower fitting. Late 1966 427 Corvette pumps use a square lower fitting. Early pumps were used until approximately 01/1966.
            No idea if they will pass judging.
            • James W.
              • December 1, 1990
              • 2657
              In my picture archives I could only find one picture of a fuel pump on a unrestored '65 396 Bow Tie car, serial #17,64x that was on display at the 2008 National Convention.
              James
              • Jim D.
                • 2884
                James, That's the same configuration as the one on mine(#16786) and stamped 40366. I don't believe it has ever been replaced but can't swear to it.
