Locked motor - NCRS Discussion Boards
Locked motor
  • Ronald R.
    • May 31, 1989
    • 671
    Re: Locked motor
    I had gas leak in cylinder after storage, 427/425 bent a rod with the starter! Easy to check
    • Jim D.
      • 2885
      Re: Locked motor
      Originally posted by Darryl Dayton (63266)
      I think PB Blaster would work better.
      Someone did a scientific test on all products for loosening rusted/frozen items and the winner hands down was a mixture of 50% ATF/ 50% acetone. I've tried it and it works better than anything I've used prior. That includes MMO, PB Blaster etc. Try it, it really works.
      • Darryl D.
        • February 7, 2017
        • 386
        #18
        Re: Locked motor
        That would be hydrolock. I had the same problem in my 58 FI car before I installed the anti syphon breaker the factory later added.
        • Domenic T.
          • January 29, 2010
          • 2452
          #19
          Re: Locked motor
          For what it's worth I have used compressed air in the spark plug hole of a piston that had both valves closed. The PSI of a 4"+ piston will be greater than wrenching the bolt. Just don't put a wrench on the bolt if you use air. The PSI of the air will multiply with the SQ " area of the piston and will be far greater than 500 lbs on the top. This will not damage anything as the combustion is somewhere around 2,000 PSI pushing the piston down when the engine is running.
          Dom
          • Mike M.
            • May 31, 1974
            • 8407
            #20
            Re: Locked motor
            snap-on make a tool that utilizes the teeth on the flywheel to turn the engine. mike
            • Roger W.
              • January 29, 2008
              • 572
              #21
              Re: Locked motor
              Make sure that none of the belts are frozen to the pullies. A friend of mine just went through this with a Chevel with a 396 that was left outside for more than 5 years. He did the MMO trick and could not turn the engine. He then discovered that the alternator was seized and the belt stuck to it. He cut the belt and the engine turned over.
              • Patrick B.
                • August 31, 1985
                • 2009
                #22
                Re: Locked motor
                I think Dom has the right idea. 100 psi on the piston is a lot of force without using a wrench.
                  • 43272
                  #23
                  Re: Locked motor
                  Originally posted by Frank Keel (33462)
                  Will pouring Marvel Mystery oil into spark plug openings free motor. Crankshaft will not turn by hand. Thanks any suggestions?
                  Frank------
                  A lot depends upon how long this engine has been out-of-service and what the conditions of its storage have been. A problem can occur with engines that have been out-of-service for a very long time and in a wet or humid environment. The cylinder walls are, of course, iron, the piston rings steel and cast iron, and the pistons aluminum. Once all of the oil is gone from the internal parts and if any moisture is present, dis-similar metal corrosion occurs. I've seen at least one engine that suffered from this for which the pistons could not be removed with a sledge hammer. I hope your problem is not that severe.
