Locked motor - NCRS Discussion Boards
Locked motor
  • Frank K.
    • January 1, 2000
    • 319
    Locked motor
    Will pouring Marvel Mystery oil into spark plug openings free motor. Crankshaft will not turn by hand. Thanks any suggestions?
  • Joe R.
    • July 31, 1976
    • 4552
    Re: Locked motor
    Well it could but I doubt it. Looks like you will be looking at the inside of the motor soon. Why do you suppose it is locked up?
    Water? Rust? Something broken?
    JR
    • Jeffrey S.
      • April 1, 2004
      • 133
      Re: Locked motor
      I have seen this method work in the past, but , if the pistons are stuck in the bores the rings are probably stuck in the piston groves so disassembly is in order in any event. I would bite the bullet and remove the intake and heads and message it from there. Hope this helps Jeff
      • Dick W.
        • 10483
        Re: Locked motor
        MMO works some of the time. Just give it several days to soak. Rock the crankshaft back and forth to break it loose.
        Dick Whittington
        • Frank K.
          • January 1, 2000
          • 319
          Re: Locked motor
          What do you mean rock the crankshaft back and forth?
          • Bob R.
            • June 30, 2002
            • 1595
            Re: Locked motor
            Try to turn the crank right then try left and so on and so on until it breaks loose.
            • Chris S.
              • January 1, 2000
              • 1068
              Re: Locked motor
              socket on the crankshaft bolt and a long breaker bar
              1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
              Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
              1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
              1957 Corvette - FI 3 sp - Black and Silver
              • Larry M.
                • December 1, 1986
                • 541
                Re: Locked motor
                If the engine is in a car, make sure the transmission is in neutral before trying to rock or turn the crank by hand.
                • Frank K.
                  • January 1, 2000
                  • 319
                  Re: Locked motor
                  Great info from all members! Thanks every one.
                  • Michael W.
                    • April 1, 1997
                    • 4290
                    Re: Locked motor
                    That could easily shear the bolt, compounding the problems.
                    • Chris S.
                      • January 1, 2000
                      • 1068
                      Re: Locked motor
                      with some common sense ...... I have done it hundreds of times and never sheared a bolt.... It works
                      • Patrick B.
                        • August 31, 1985
                        • 2009
                        Re: Locked motor
                        Comp Cams and others make a crank socket that uses the crank key and thus allows as much torque as possible in both directions. Use can use a big breaker bar or even an impact wrench with one of the fairly cheap tools.
                        • Michael W.
                          • April 1, 1997
                          • 4290
                          Re: Locked motor
                          Common sense is an optional extra with many hand tools
                          • Ronald R.
                            • May 31, 1989
                            • 671
                            Re: Locked motor
                            Make sure all spark plugs out could be hydro lock
                            • Darryl D.
                              • February 7, 2017
                              • 386
                              Re: Locked motor
                              I think PB Blaster would work better.
