1966 Rubber Fuel Line Spring Clamps - NCRS Discussion Boards
  • Timothy B.
    • August 4, 2008
    • 44
    I am replacing rubber fuel line that runs from the fuel pump to the metal line.
    Does anyone have an easy way to place the spring clamps on that hose?
  • Jim D.
    • 2885
    Re: 1966 Rubber Fuel Line Spring Clamps
    Hose clamp pliers makes it a simple task.
    • Timothy B.
      • August 4, 2008
      • 44
      These are the spring clamps that are black with the three tabs and supplied with the fuel hose from Paragon.
      • Timothy B.
        • August 4, 2008
        • 44
        These clamps that I am dealing with are the three prong spring clamps that Paragon sends with the fuel line hose.
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11364
          I have always used these....
          Just a FYI, the replacements are different from originals.
          Replacements have rounded tabs,
          originals have square tabs,
          (Photo courtesy of Doc Rebuild)
          • Jim D.
            • 2885
            Oops, I thought you were referring to the wire spring clamps. For the clamps you're talking about, I use Duckbill pliers.
            • Timothy B.
              • August 4, 2008
              • 44
              Thank you!
              I removed the heater hose put the clamps on the hose and forced the hose on the tubes
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11364
                Originally posted by Timothy Beilby (49312)
                Thank you!
                Heater hose? Typo?
                • Dick W.
                  • 10483
                  And mill bastard files make round things square.
                  Dick Whittington
                  • Richard M.
                    Super Moderator
                    • August 31, 1988
                    • 11364
                    Yes but a sharp eye can see it's just a tad shorter than originals after filing. I've witnessed this during my tenure while seeing the judges in action.
                    • Stephen L.
                      • May 31, 1984
                      • 3162
                      You can make those "rounded tips" "original" square, with a quick touch to a grinder and a little olive drab paint......
                      • David P.
                        • October 26, 2015
                        • 49
                        I would use a set of special hose clamp pliers for those. Those ears snap off pretty easily. I use a pair from Blue Point. Other companies make them as well.
