Rhoads Lifters - NCRS Discussion Boards
Rhoads Lifters
  • Ralph P.
    • February 1, 1990
    • 253
    Rhoads Lifters
    What's the word on the value of these hydraulics? They are advertised to increase vacuum & torque at lower RPM's while allowing same or higher performance in high rev range. I know Crane had their own version. Any downside?
    THANKS
    • 6948
    Re: Rhoads Lifters
    Ralph, these style lifter where used when cam profiles with high lift and long durations where installed, many engines with a lot of vacuum run accessories had problems staying operating at idle.
    • Jim D.
      • 2885
      Re: Rhoads Lifters
      Never used them but the two friends that tried them removed them because they are noisy and didn't perform as advertised. Why not simply use the correct cam in the first place?
        • 15706
        Re: Rhoads Lifters
        Agree. Decide what kind of torque bandwidth you want, then select a cam to achieve it. Anything less than 80 percent peak torque at 2000 is going to be a soggy engine in normal road driving. The base engine and McCagh Specials cams make about 90 percent at 2000, and all SHP cams except the 30-30 make the 80 percent bogey.
        For any cam if you want more top end power and usable revs, massage the heads.
        • Ralph P.
          • February 1, 1990
          • 253
          Re: Rhoads Lifters
          Thanks, Guys...... Good advice as always!
