Faulty sensor on Airbag code 25 - NCRS Discussion Boards
  • Ed H.
    • November 1, 1999
    • 626
    I am looking for anyone that might have a Tech Service Bulletin that addresses the fault and the relief of said milady.
    I was informed by a very knowledgeable C-4 judge at Bloomington, this past June, that it might be a grounding problem.
    I went looking for the little offender but I have no joy in finding it or what it looks like.
  • Ed H.
    • November 1, 1999
    • 626
    Can anyone help me to locate the sensor and instructions on how to repair or replace. It might be a grounding problem.
    When the sensor misbehaved the seat belt light came on and will not go off. Ain't computer vettes fun. Oh for my 57 again.
    • Rick A.
      • July 31, 2002
      • 2147
      Re: Airbag Sensor fault code 25
      Ed - found this on an Google is My Friend search - According to Gordon Killebrew, "If fault codes 15,16,25 or 26 are set, refer to GM bulletin 90-436-9J. There may be corrosion between the right or left uniframe impact sensors and the uniframe." The sensors are bolted to the frame rail and they use the bolts/mounting tabs as a ground. The fix is to remove the sensors and clean up the tab and frame area and apply some di-electric grease and use star washers on the remount. So if you clean the sensors and the frame like I suggest and reset the light you should have no more problems. Of course there is a possibilty it could be a bad sensor, but more than likely it will be a bad ground(the sensor to the frame). If all else fails Gordon is only a phone call away.....................
      Rick Aleshire
      2016 Ebony C7R Z06 "ROSA"
      • Rick A.
        • July 31, 2002
        • 2147
        Ed - as a follow-up, they placed the sensors in corrosive areas on the frame rails at the wheel openings and under the battery. There is also one up under the steering column inside. Hope you can find them..............
        Rick Aleshire
        • Ed H.
          • November 1, 1999
          • 626
          Thanks Rick. I talked to Tom Barr and he had the same problem on a rear sensor. I guess I have to take off the fined plate on the Pass. side,
          then remove the inner fender panel. then look for the "YELLOW WIRE'.OH BOY, ALSO Tom said be sure to turn off the battery or I may suffer
          the same surprise I did during the Mech session for my Cross Flag judging. I HAVE NOT FORGOTTEN I WILL RETURN!
          • David H.
            • June 30, 2001
            • 1544
            Ed,
            Looking at the 1996 Service Manual - Ground for LH/RH Discriminating Sensors and Diagnostic Energy Reserve Module (DERM) is Ground 106 (G106) located LH rear of Engine near Oil Filter not exactly help on your 1990.
            However, if you have 1990 Service Manual look in front section of Electrical Diagnosis (1996 Section 8A-14-2 for G106) for "Ground Distribution". Look for "Discriminating Sensors" and "DERM" on wiring diagrams - you won't find reference to SIR / Air Bags / Supplemental Inflatable Restraint / etc on those diagrams.
            Narrative description of location should follow a few pages later in Service Manual. Perhaps why grounds were moved from frame to engine.
            Dave
            Judging Chairman Mid-Way USA (Kansas) Chapter
            • Ed H.
              • November 1, 1999
              • 626
              Thanks David and Rick. I went to my local Chev dealer with the info provided by Rick. and they printed out a copy of the TSB. That explains everything. Sorry to disturb your nap Hooper.
              • Rick A.
                • July 31, 2002
                • 2147
                That was quite the "exhilarating" surprise! (VBG) Glad you were able to get the TSB printout
                Rick Aleshire
                • Jack M.
                  • March 1, 1991
                  • 1170
                  Re: Faulty sensor on Airbag code 25
                  Ed- I'm not certain what data you received from the dealership... perhaps this info will assist: CLICK HERE
                  • Ed H.
                    • November 1, 1999
                    • 626
                    Joe, that is a copy of the same TSB, numbers matching. Thanks for back stopping Rick. All is well now
                    • Rick A.
                      • July 31, 2002
                      • 2147
                      Ed - glad to hear you have 'spark"!
                      Rick Aleshire
