65 BB transmission questions - NCRS Discussion Boards
  • Richard S.
    • January 30, 2017
    • 20
    I am looking for some clarification on my 396 transmission numbers.
    The NCRS shipping report on my car shows the production date of 6/21/1965.
    Drivers side of transmission has an assembly code P0513.
    Drivers side cover code 383170
    Vin stamping number matches the car Vin number
    Passengers side of transmission has an assembly code P0622
    Muncie casting number 3851325
    Bell housing number is 385840
    Can somebody please clarify the meaning of the 2 different assembly code numbers and how they work with a car build date of 6/21/1965. All opinions would be appreciated.
  • Carl N.
    • April 30, 1984
    • 592
    Re: 65 BB transmission questions
    Wow, never seen this before. May date works, June date ?? Maybe a mis-stamp on the 6. L78 option should not matter, most L78's were built in late May thru end of July
    • Jim D.
      • 2885
      Never seen an assembly code stamped on the drivers side. Both my 65's, SB & BB, have the assembly code stamped on the PASS. side. The only thing stamped on the drivers side is the VIN and the metal tag attached to the side cover. SB car built 4-10 is stamped P 03 29. BB car built 5-5 is stamped P 04 19.
        • 6955
        Rich, lets see the stamps on both? might help determine what happened.
        • Richard S.
          • January 30, 2017
          • 20
          • Richard S.
            • January 30, 2017
            • 20
            Hopefully these help
            • Tom D.
              • September 30, 1981
              • 2143
              I think the date on your trim tag is the date the tag (for the body) was made. Does it differ from the NCRS supplied date?
              Could someone in the factory (St. Louis, not Muncie) have added the P0622 on 6/22/1965?
              https://MichiganNCRS.org
              Michigan Chapter
              Tom Dingman
              • Jim D.
                • 2885
                I'd like to see the VIN stamping.
                • Richard S.
                  • January 30, 2017
                  • 20
                  It looks like trim tag shows K21 which i think is June 21. One thing i was looking at is the 65 Judging manual on page 221 refers to numbers on both sides under the for reference only section.
                  • Jim D.
                    • 2885
                    The body build date of June 21 and the shipping report showing the same date is possible but only with St. Louis bodies. My body date is May 4 and a shipping date of May 5.
                    Page 221 in the Judging Guide states that the assembly date is on the pass. side and the VIN on the drivers side. It says nothing about an assembly stamp on the drivers side.
                    Please post a pic. of the VIN stamp that's on the drivers side of the trans.
                    • Richard S.
                      • January 30, 2017
                      • 20
                      The judging guide page 221 says that all base manual transmissions have the assembly code stamped on the drivers side. Is the base transmission they are referring to the 3 speed manual transmission? I have attached the vin stamping
                      • Jim D.
                        • 2885
                        Yes, the base trans. was a 3 speed and not available with the L-78. A couple things about the VIN - it's very lightly stamped for being in aluminum (mine are very deep) and both of mine, and all that I've seen, are stamped so they are read from standing behind the trans. Yours is the opposite. Minor details I know but BB Corvettes, especially 65's being very rare, are commonly faked. I'm not saying yours is but that trans. does raise some questions.
                        • Richard S.
                          • January 30, 2017
                          • 20
                          Appreciate your input and knowledge. As i am learning this will be a long process.
                          • Ronald L.
                            • October 18, 2009
                            • 3248
                            The P date on the machined polished surface - driver side is-was a 1964 Muncie Pdate.
                            This does have some of the coding that is hard to make disappear and validates it as a 1964 Muncie Main case.
                            Also - that main case was CAST January - 3rd week, and would not be typical to be until May 13 for this to be used for production.
                            Worse is how does this get a 1965 P date of June 22 for a car build June 21???
                            Very likely in the history someone did not see that or know what it was and put (re-stamped) the P date on the pass side...
