one of back wheels very hot to touch----other wheels fine - NCRS Discussion Boards
  • Thomas G.
    • April 29, 2017
    • 4
    I can feel the hot wheel and smell the overheating on the driver side rear wheel only. The brakes are not locked up and work fine. Just completed a complete rebuild. Any ideas? Bearings?, Need help. Thanks Its on a 1964 corvette conv 327
    • 43258
    Re: one of back wheels very hot to touch----other wheels fine
    Thomas------
    If you're sure it's not a brake problem, then I'd say it's a rear wheel bearing problem. Before I got into that, though, I'd want to be certain it's not actually a brake problem.
    • Thomas G.
      • April 29, 2017
      • 4
      thanks, I will recheck the brake cylinder etc.
      • Leif A.
        • August 31, 1997
        • 3646
        Emergency brake partially hanging up/out of adjustment??
        Leif
        • Tracy C.
          • July 31, 2003
          • 2739
          Just raise the car and see how easily the wheel rotates in neutral as compared to the other. If you have a brake drag issue it will be obvious.
          tc
          • Edward B.
            • January 1, 1988
            • 537
            Replace the flexible hose at the hot wheel. It that cures the problem, replace the others as well since their time is drawing nigh.
              • 6950
              Tom, the post from Ed maybe be on the right track if you find the adjustment where it's suppose to be. a imploded hose is the inner layer of the hose clasping closed and holding the brake on. generally what I would do is jack up the rear wheel, before you touch the pedal and see if it spin's freely, If okay, then step on pedal once and see if the wheel is locked, this will confirm a hose Issue.
              • Thomas G.
                • April 29, 2017
                • 4
                Thanks for all the help....I will check wheel tomorrow. Doubt its a hose since the entire car and braking system has less than 1000 miles since rebuild. I feel it is probably a brake problem.
                • Joe R.
                  • July 31, 1976
                  • 4551
                  Thomas,
                  Complete Rebuild? That include the rear wheel bearings?
                  Is the wheel hot or the tire hot?
                  When going down the road does the car pull left or go straight when you let go of the steering wheel.
                  Need more facts and research from you!
                  JR
                  • Frank D.
                    • December 27, 2007
                    • 2703
                    Sometimes it pays to go back and do a QA check on brake work....there are several 'gotchas' that can come into play...
                    The self adjusting torpedoes have to go on the proper side; there is usually an "L" or an "R" on the end of the piece as an indicator.
                    I've seen the long spring across the adjuster installed backwards so that the pawl was in a bind....and on and on..
                    Its a few minutes to pop the drums off and take a look see.
                    • Thomas G.
                      • April 29, 2017
                      • 4
                      Everything rebuilt, brake lines, cylinders, trailing arms, etc. I am thinking its a sticking emergency brake, like in adjusted too tight. Am going to look into that today. Thanks for everyone's help and suggestions.
