wheel code - NCRS Discussion Boards
wheel code
  • Thomas J.
    • March 10, 2017
    • 22
    wheel code
    looking at set of wheels stamped k187 23 az can someone tell me the date? thanks
    • 15630
    Re: wheel code
    February 3, 1987
    • Thomas J.
      • March 10, 2017
      • 22
      Re: wheel code
      thank you terry
      • Howard H.
        • January 10, 2007
        • 139
        Re: wheel code
        I believe it is July 23, 1968
          • 15630
          Re: wheel code
          That could be Howard, depending on the spacing (location of the numbers) of the code. I took it that the valve stem was between the 7 and the 2 because of the space Thomas left in the code. I could have made an inaccurate assUmption. I can tell you I have seem SERVICE wheels produced in the late 1980s with two digit year codes.
          • Mike E.
            • February 28, 1975
            • 5141
            Re: wheel code
            Much more likely that it is July 23, 1978. Those would be extremely early 69 wheels if built in July 68.
