95 Opti Spark Dist. question - NCRS Discussion Boards
    • 6948
    Guys I looking for a replacement dist. this car currently has a Accel Dist. that has problems from the get go. what are some of you C4 owners doing. Thanks, Ed
  • Joe R.
    • July 31, 1976
    • 4551
    Re: 95 Opti Spark Dist. question
    Ed,
    Optisparks are cheap on e-bay and I am careful to NOT wash the engine and try to keep the leaks to a minimum. You can buy over 10 Optisparks on e-bay for what one Accel Dist. costs. Yes, it's a pain in the rear to change them but it saves money in the long run.
    JR
      • 43246
      Ed-------
      Well, GM and AC-Delco still offer a 95-96 Opti-Spark. Officially, it's a rebuilt unit although the actual part might be new. The part number is GM #19212300. The problem is that it carries a GM list price of over 700 bucks + $75 core charge. However, you can buy this unit a lot cheaper through discount GM dealers or AC-Delco dealers.
      My guess would be that this unit is about the best one could do for a replacement. As I've said many times before, Opti-Sparks are the "Achille's Heel" of Gen II small blocks.
      • Frank K.
        • January 1, 2000
        • 319
        Go to rock auto just bought two GM . Do not know if they have been rebuilt but i will tear down one to see if they have the Mitsubitchi optical disc. They were under a grand less if you give up your core $375.00 give or take.
          • 6948
          Thanks for the info guys.
