1968 Differential Stamping Location - NCRS Discussion Boards
  • Gregory M.
    • May 31, 1984
    • 178
    Where is the stamping on a 68 differential that shows date assembled and ratio? Any photos?
    I assume there is also a casting number and date on the housing? Where are they located? Any photos?
  • Jim D.
    • 2884
    Re: 1968 Differential Stamping Location
    These are from one of my 65's but 68 is probably the same.
    • Gregory M.
      • May 31, 1984
      • 178
      God, those pics are beautiful! Something about a clean cast finish...thanks so much.
      Questions. a) Is that stamp on top or bottom? b) Why 2 casting numbers?
      • Jim D.
        • 2884
        The stamp is on the bottom just in front of the spring. Those are two different parts, the main housing and the rear cover, hence the two casting numbers.
        • Gary R.
          • April 1, 1989
          • 1798
          It will be in the same locations as the '65. Pretty much the same diff as the 65 as well both good and bad aspects.
          • Chris B.
            • June 22, 2014
            • 8
            Hi Gregory, my 68 had the code and date stamp on bottom between the spring and the strut rod bracket. Chris
            • Gregory M.
              • May 31, 1984
              • 178
              Awesome...other than assuming that 2 21 68 is the date, how is the rest of the stamp read?
              • Chris B.
                • June 22, 2014
                • 8
                I remember doing a google search that took me to a site that had the codes (the stamping to the left of the date) translated. In my case "2AU" is a 3:36 heavy duty posi. I don't have the site handy right now but try a search for 68 corvette differential codes.
                  • 15599
                  The differential codes, and a whole lot more, are in the 1968-69 Technical Information Manual and Judging Guide (TIM&JG) available from the NCRS Store in the drop-down menue at the top of this page.
