Cooling Temperature Sensor - NCRS Discussion Boards
    • 43219
    Re: Cooling Temperature Sensor
    Originally posted by Frank Keel (33462)
    The 213928 gm was my choice !
    Frank-----
    It could very well be the AC-Delco 213-928.
      • 15599
      This is for the LT1 equipped Caprices:
      COOLANT - TEMP SENSOR (PCM) NEW P/N 15326386 12146312
      COOLANT - TEMP SENSOR (PCM) AC# 213-310 15326386
      COOLANT - TEMP SENSOR CONNECTOR 12102748
      A note says: "With oil pressure gauge and light" although I can't for the life of me figure out what oil pressure has to do with this sensor.
      These numbers go back to the turn of the century, so they may be horribly out of date by now, not to mention they are not for a Corvette application. My best memory is these have two pins, side by side. If you want confirmation I can look at that tomorrow int he daylight.
        • 43219
        #18
        Terry------
        The GM #15326386 remains available. The others are discontinued.
        • Frank K.
          • January 1, 2000
          • 319
          #19
          Do they have a ohm value?
            • 15599
            #20
            Not in any of the documentation that I have.
            • Frank K.
              • January 1, 2000
              • 319
              #21
              Just found in Chilton Corvette book the off vehicle testing of the cooling temperature sensor. Useing a Fluke RMS meter or any meter it can save you time. Note,GM has a special insulator built in to sensors base. I would not substitute any other after market manufactures part!
