Cooling Temperature Sensor - NCRS Discussion Boards
  • Frank K.
    • January 1, 2000
    • 319
    What is the correct GM part number for a 1993 base car?( located on water pump)
  • Keith B.
    • September 15, 2014
    • 1596
    Re: Cooling Temperature Sensor
    Before changing this sensor double check the conector for corrosion and continuity of both wires from the ECM and he ground is good.
    • Frank K.
      • January 1, 2000
      • 319
      I need the sensor first and the service manual has no means of support to check it out. So a new GM for my year would be a quick screw in . As far as corrosion the electrical connector looks fine but who knows what the water pump internals hold! As far as grounds the re find.
      • Keith B.
        • 1596
        That's odd becouse my 94 FSM had the steps to check it out. I had my trouble with replacement sensor there.
        • Frank K.
          • January 1, 2000
          • 319
          I found a pre 90 sensor tester Actron CP9087 The two Z28 convertibles would just cut at any time on the highway that i owned so that is why i have this.
          • Keith B.
            • 1596
            How are you determining you need a sensor?
              • 43263
              Frank------
              What is the configuration of the connector on the sensor? Is it 2 pins or is is a blade and a pin?
              • Frank K.
                • January 1, 2000
                • 319
                Two pin on water pump
                • David H.
                  • June 30, 2001
                  • 1552
                  A downloaded fiche I have, shows 1992-96 LT1 Thermostat as pn 12555290. 180 degree (AC-DELCO #131-100)
                  Dave
                  • Frank K.
                    • January 1, 2000
                    • 319
                    Not looking for thermostat. On the water pump there is a two pin connector which reads coolant temperature whichin closed loop tells computer to lean or rich fuel.
                      • 43263
                      Frank------
                      Are you sure that the pins on the sender are two EQUAL-SIZED PINS? A photo of it, especially of the pins, might be helpful.
                      • Frank K.
                        • January 1, 2000
                        • 319
                        Two round pins on the sensor Bayonet type (horizontal side by side)
                        • David H.
                          • June 30, 2001
                          • 1552
                          Dave
                          Frank,
                          2nd try. Coolant Sensor for 1992-96 LT1 is 25037332. AC DELCO #213-77.
                          Dave
                            • 43263
                            Dave and Frank-----
                            That's what I thought, too. However, the GM #25037332 temp sender has, side-by-side, a blade terminal and a pin terminal. That's not as Frank describes his. I've just hit a "brick wall" in coming up with the correct temp sender. It might be a GM #19189478 or GM #19187357.
                            • Frank K.
                              • January 1, 2000
                              • 319
                              The 213928 gm was my choice !
