Any problem aligning the suspension with KO Wheels? - NCRS Discussion Boards
  • Gary R.
    • April 1, 1989
    • 1799
    I send the cars I build suspensions on to a local garage that is good, but this is the first time for KO wheels and I was concerned about marking the wheel rim where the alignment heads mount. Any thoughts on this or will some masking tape at the contact point solve it?
  • Russ S.
    • April 30, 1982
    • 2162
    Re: Any problem aligning the suspension with KO Wheels?
    They need to use plastic protective covers on the tire machine jaws.
    • Gary R.
      • April 1, 1989
      • 1799
      Thanks Russ this would be for the alignment heads that clamp on the wheel rim on the rack, is that what you are referring to?
      • Russ S.
        • April 30, 1982
        • 2162
        No Gary. I was completely out in left field. For some reason I was thinking of a tire machine for dismounting tires.
        • Gary R.
          • April 1, 1989
          • 1799
          Not a problem Russ.
          • David R.
            • February 1, 1990
            • 71
            Look for a shop that has the most current Hunter Alignment systems. They use a target that mounts to the wheel/tire. The target has a soft rubber contact with the wheel face. They grab the tire tread and never have any metal to metal contact. It is a camera based system and is very accurate.
            You shouldn't have any issues with rim damage with this type of alignment system. I just used this system on my 2006 GMC 2500HD and I didn't need to take off the wheel centers.
            • Gary R.
              • April 1, 1989
              • 1799
              Thanks Dave,
              I have to admit I haven't seen that type on a Hunter before. The shop I use has about a 10 year old machine now and I have to say it's pretty nice. In addition to alignment it's a full service lift.
