C7 Cut Off Switch - NCRS Discussion Boards
C7 Cut Off Switch
  • Dick C.
    Past NCRS President
    • November 1, 1995
    • 454
    C7 Cut Off Switch
    Anyone install a battery cut off switch in their C7 ?????
    Have not looked at the battery yet.
    Not sure if it a top post or a side post
    Registered for Sportsman at the National and its required.
    Dick Capello
    New England Chapter/Mid Atlantic Chapter
    Past NCRS President
    Past Region 1 Director
  • Rich G.
    • August 31, 2002
    • 1405
    Re: C7 Cut Off Switch
    Won't that cause you to put all your user options in every time you reconnect the battery, or is there some sort of memory that doesn't require power?
    Rich
    • Dick C.
      Past NCRS President
      • November 1, 1995
      • 454
      Rich,
      I am told that all I my loose is the window indexing.
      Rich
      Dick Capello
      Past NCRS President
        • 15632
        I believe the C7 is top post -- my C6 is top post. On battery disconnect all one loses on the C6 is the window indexing, but I can't speak to the C7.
        • Michael J.
          • January 27, 2009
          • 7167
          I have heard this fused bypass circuit battery shutoff switch will qualify as a shut-off switch, since the car can't be started but it keeps a small amount of current flowing through the car's electrical system to retain everything.
          http://www.jegs.com/installationinst.../555-10321.pdf
          • Rich G.
            • August 31, 2002
            • 1405
            Dick,
            Thanks. I had a C6 Z06 and it was top post. I thought I lost radio pre sets once when I let the battery go too low, but it was probably caused by something else. I'm sure you guys are correct.
            • Ken R.
              • August 31, 1980
              • 309
              Easier to just unhook battery terminal on C7. I didn't loose anything last time. Doesn't mean it won't loose something though on a C7.
                • 15632
                Gee Ken, that is a lot different than a C6.
                • Ken R.
                  • August 31, 1980
                  • 309
                  I didn't even show what is under the black cap on left side. And you better carry a battery lift device with you if you ever have to remove the battery or better have very strong fingers.
                  • Dick C.
                    Past NCRS President
                    • November 1, 1995
                    • 454
                    Ken, The positive post is under the black cap.
                    I am just going to disconnect the negative cable.
                    Simple and easy
                    Dick Capello
                    Past NCRS President
                    • Michael J.
                      • January 27, 2009
                      • 7167
                      Wow! It sure is! And I thought the C6 was tight and inaccessible............
                        • 15632
                        Simple and easy
                        What else is under the rest of the black package? Is that the "battery saver" equipment, or is it a charging apparatus?
                        • Mark G.
                          • January 31, 2007
                          • 177
                          This is what is under that black cover to the left of the battery. Are you looking to do a battery disconnect or something to shut off the engine? If the latter, do you need it to be readily accessable from the drivers seat? The one I did had the switch mounted to the roll cage, but I'm sure yours is a street car.
