Starting My Oil Change Projects>Here Is the Cost Of PF35L's & Mobil1 15W-50 Synthetic - NCRS Discussion Boards
  • Mark G.
    • January 31, 2007
    • 177
    Re: Starting My Oil Change Projects>Here Is the Cost Of PF35L's & Mobil1 15W-50 Synth
    That's what I use along with a bottle of zddp plus. Walmart by me has 5 quart jugs of mobile 1 for $22.88
      • 15680
      If you're using an engine oil with at least 1100 ppm P you don't need a "ZDDP additive" or any other snake oil.
      • Larry E.
        • 1681
        #18
        Question for Duke: One of my other cars for the oil to be changed is a 94 Camaro LT1. (Same engine in a Vette)
        Should I stay with the 15W-50 Mobile 1 or should I use the 10W-30 Mobile 1? Does it make a difference? Larry
        P.S. I believe this engine came with roller lifters
        Larry
        LT1 in a 1LE -- One of 134
        • Michael W.
          • April 1, 1997
          • 4290
          #19
          Which year Corvette and which LT1 engine are you referring to?
          • Mark E.
            • April 1, 1993
            • 4557
            #20
            I believe all LT-1 engines from the '90s have roller cams.
            Mark Edmondson
            Dallas, Texas
            Texas Chapter
              • 15680
              #21
              If it's a roller cam you can use any S or C-category oil... doesn't make any difference. Appropriate viscosities for the range of cold start temperatures are in the owner's manual. If you drive it less than a few thousand miles every year or two and change the oil at least every couple of years there's no advantage to using a "synthetic" oil.
              • Keith B.
                • September 15, 2014
                • 1583
                #22
                starting in 87 all GM SB got them
