Water Pump gaskets C4 - NCRS Discussion Boards
  • Frank K.
    • January 1, 2000
    • 319
    I see no gasket cement on my C4 water pump. I see the after market pump installation memo not mentioning the adhesive . Is this necessary to hold the two gaskets on the block or is it for water imperfections in the castings. Also is silicone the adhesive to use or special water pump only glue?
  • Keith B.
    • September 15, 2014
    • 1591
    Re: Water Pump gaskets C4
    I use Indian Head Shellac. Worked for me
      • 43259
      Keith and Frank------
      Indian Head works great; I've used it for years. However, I don't think I'd use it for waterpump-to-block gaskets. That's because if you have to remove the waterpump again, it's going to be a miserable chore to clean off the sealer. Instead, I'd use a silicone RTV which Permatex makes explicitly for cooling system applications. And, I'd use only a VERY THIN film on both sides of the gaskets.
        • 15621
        Whatever product one uses, I have found putting it only on the water pump is an advantage for the next replacement. That practice makes the cylinder case easier to clean as most of the gasket material usually stays with the removed water pump. If desired, the water pump is easily cleaned on the bench. I have never had an issue with a water pump leak, but I also look up the torque specs and use a quality torque wrench.
        If I owned a C1 with the engine mount front plate between the water pump and cylinder case I might reconsider my practice, but that is not a factor for me.
