Window Regulator question - NCRS Discussion Boards
  • Keith R.
    • August 31, 2001
    • 660
    Getting ready to reinstall the door window mechanisms and I noticed that the two arms opposite the sector gear (which appear to be pressed on) are tight on one regulator and relatively loose on the other one. Are the loose arms a concern with smooth window operation? Is there a way to tighten them up?
    Keith MacRae
    NCRS #36692
    New Mexico Chapter
    1960 290HP FI
    2013 427 Convertible
    Shade tree mechanic and
    B-52 pilot extraordinaire
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11335
    Re: Window Regulator question
    Keith,
    I'd lubricate the tight joint with a light oil.
    That loose joint? It should have a specific angle when pressed together. Those 2 arms(short/long) should not open or close with respect to each other. If they do, the internal square locking tabs are worn and may need to be opened up by grinding and reassembling.
    If the 2 arms are properly angled, but loose with respect to the main arm, you could snug up with a few hits with a hammer against one end of the clamping head, with the opposite side on anvil or vice table. Don't go too much though as to make it too tight. A few hits at a time and check between hits.
    Just took a few pics of a old one from my '62 for reference.
    Rich
    • Keith R.
      • August 31, 2001
      • 660
      Thanks Richard. The two arms are fixed in position with regard to one another but are rather loose on the main arm. I thought that I might whack the clamping head to see if I could tighten it up but wasn't sure if that would do the trick.
      Keith MacRae
      NCRS #36692
      New Mexico Chapter
      1960 290HP FI
      • Keith R.
        • August 31, 2001
        • 660
        Whacked them good on a vice with a BIG hammer and it didn't seem to make any difference....
        Keith MacRae
        NCRS #36692
        New Mexico Chapter
        1960 290HP FI
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11335
          Keith, Typically there is so much play in window regulators by design, so you may want to use it as is. I think your only other option is a replacement, but you may not even notice the difference while "cranking" after completion.
          Rich
          • Keith R.
            • August 31, 2001
            • 660
            I agree. If the guides and runs are securely in place, then the window should follow along I would think.
            Keith MacRae
            NCRS #36692
            New Mexico Chapter
            1960 290HP FI
