Inspection Paint dabs - '64 - NCRS Discussion Boards
  • Ed S.
    • August 6, 2014
    • 1388
    Am rebuilding / restoring my drive train from the trans back and am about ready to begin reassembly. Looking in the TIM / JG for info on "inspection paint dabs" on the: driveshaft, diff, U-joints, half-shafts (axles) and rear suspension components. I find no mention of inspection paint dabs in the judging guide on any of these components.
    I researched the TD forum for info on this issue - some members stated that not all cars coming down the assembly line received inspection paint dabs. I am guessing this is why there is no mention of paint dabs in the judging guide, it was not a universal process.
    Since it does not list or mention paint dabs on the components I listed above, am I correct in assuming that I do not need to apply them? I assume there will be no point deduction if they are not present - correct?
    So, the question is, is it necessary to apply inspection paint dabs?
    I know Quanta sells an inspection marking kit with every conceivable color that might be needed - key word is "might".
    Ed
  • Bob R.
    • June 30, 2002
    • 1595
    Re: Inspection Paint dabs - '64
    I don't think 64 had any paint on the drive shaft there are some paint markings on the front suspension and markings on the frame.
      • 6956
      Ed, they do not judge the inspection marks, what I Do is if there is a mark take a photo and the if your restoring the part you can re-apply as it looked. I have restored a few 64 chassis's and each one was different. If you remove the marks during restorations and reapply its just a duplicate, its only original once so they say.
      • Ed S.
        • August 6, 2014
        • 1388
        Bob, Edward,
        Thank you for your replies and guidance. You have confirmed what I surmised from reading the JG but it is always prudent to get the advice of experts.
        Ed
        • David R.
          • February 1, 1990
          • 71
          Driveshaft marks from my 64:
