1964 corvette steel wheels - NCRS Discussion Boards
  • John F.
    • March 23, 2008
    • 2409
    Corvette Specialties is advertising a set of exact reproduction wheels. How do they stack up for judging?
  • Harry S.
    • July 31, 2002
    • 5301
    Re: 1964 corvette steel wheels
    The date is not stamped on the inside but you can't see that anyway while judging. There is a DOT stamp on the inside of the wheel. It would be hard to see during judging. You can JB weld over it and sand/paint. Other than that I think they are fine.
    • Rick A.
      • July 31, 2002
      • 2147
      agree with Mr Sadlock
      Rick Aleshire
      2016 Ebony C7R Z06 "ROSA"
        • 6942
        John along with Harry, my car and one other all had the CS wheel's on the car all went through last years Nationals with no hitchs.
        • Richard G.
          • July 31, 1984
          • 1715
          Which Corvette Specialties?
          One in Oregon, Maryland and CA..
          I looked at the web sites of them all and failed to find the sale.
          • Bob R.
            • June 30, 2002
            • 1595
            I believe it is called Corvette Specialties of Maryland but I think they moved to California a couple of years ago. They may advertise in the Driveline there is only one company making them but there may be several vendors selling them.
            • Tracy C.
              • July 31, 2003
              • 2739
              I've not seem the reproduction however I remember a past discussion about the spyder being welded to the rim in a non typical fashion.
                • 6942
                Yes the wheels are welded no spot welded Tracy. there are not 100 % correct, but when on the car they are not visible.
                • John F.
                  • March 23, 2008
                  • 2409
                  Thank you guys. I really appreciate the info!
                  • Brian T.
                    • September 30, 1990
                    • 190
                    Gentleman, the reason the wheels are welded from the hub to the rim in that fashion is easy. DOT. Spot welding or plug welding is a no no in modern wheels. Specific stamping differences are also due to regulations.
                    Of course, that is why you do not see riveted wheels as well.
                    Brian
