1970 L46 Distributor 1112021 Shaft part number. - NCRS Discussion Boards
  • Stephen V.
    • July 23, 2016
    • 30
    What is the correct OEM part # for a 1112021 distributor shaft and would a NOS replacement be considered a high performance shaft as well ?
    • 43222
    Re: 1970 L46 Distributor 1112021 Shaft part number.
    Stephen-----
    The original part number for the mainshaft with autocam was GM #800476. However, it's long-since GM discontinued. This shaft was used for a distributor used for "high performance" applications. So, presumably, it's "high performance".
    • Stephen V.
      • July 23, 2016
      • 30
      Thank's Joe. Think I will go with the High Performance shaft !
        • 43222
        Stephen-------
        If you want to maintain original centrifugal advance characteristics, if you have an original shaft, your best bet is to have the autocam removed from your original shaft and transferred to a new shaft.
        • Stephen V.
          • July 23, 2016
          • 30
          Joe , I will do that. Thank you for this information !
            • 15680
            The '69 L-46 distributor is not "high performance". It is emission control! For example, max centrifugal is 26 @ 5000. I don't know which of the two aftermarket shaft replacements will work best, but go with the "high performance", and see what you can get with lighter springs. I would not recommend transferring the original "football" to the new shaft. It's not worth the risk.
            See my 2012 San Diego national convention tuning seminar. It's a easy Web search.
            s
              • 11644
              Ironically, when I talked to my distributor rebuilder about the shafts he found that the one sold as normal had a better performance autocam than the one sold as "high performance." If you're going to swap your original autocam onto it anyway, buy the cheaper one as the only difference is the cam unit.
              • Stephen V.
                • July 23, 2016
                • 30
                Thank you Duke.
                • Stephen V.
                  • July 23, 2016
                  • 30
                  Thank you Patrick.
                  • Stephen V.
                    • July 23, 2016
                    • 30
                    Thank you for all the replies. The original shaft had the HP cam unit on it. The replacement shaft came with an identical one on it that I used. Installed and running good !
                      • 43222
                      Stephen------
                      What number was stamped on the original cam, either on the top or on the bottom?
                      • Stephen V.
                        • July 23, 2016
                        • 30
                        #83 on top of the shaft where springs go. 730 CCW on the bottom of the cam.
                          • 43222
                          Stephen------
                          Those are the correct original parts for the L-46 distributor.
                          • Stephen V.
                            • July 23, 2016
                            • 30
                            Thank you Joe.
