Re: 1967 Battery Mishap - Burning smell
Gene, There are 2 at the VR to protect the alternator and VR wiring.
2 at the starter solenoid feed supplying the horn relay buss bar and the Battery Meter source terminal.
1 at the horn relay buss bar as the source for entire car electrical load.
Here is a Early 1967 harness. VR/Alt section, 2 links.
Early type with the separate Plug-Type fusible link at the horn relay buss bar. Later cars and service replacement harnesses used the black barrel type joint as shown above.
