L-82-L-48 seals - NCRS Discussion Boards
L-82-L-48 seals
  • Frank K.
    • January 1, 2000
    • 319
    L-82-L-48 seals
    Is there any difference on the intake or exhaust size seals when changing out Can the keepers be cleaned and re used? What are the L-82 part numbers if different? (Fel Pro or equal)
    • 43258
    Re: L-82-L-48 seals
    Frank------
    There is no difference between intake and exhaust valve seals and there is no difference between L-48 and L-82 valve seals. All of these use an "o-ring" type seal. GM #102114034, Fel-Pro SS5112, or Sealed Power MV1233C.
    The valve locks ("keepers") can be re-sued if not worn or damaged.
    • Frank K.
      • January 1, 2000
      • 319
      Re: L-82-L-48 seals
      Are the valve stem seals (rubber) umbrella, are they viton? Do you know oe part numbers Thanks Frank
        • 43258
        Re: L-82-L-48 seals
        Frank------
        No pre-1981 Corvette small block (e.g. any L-48 or L-82) ever originally used umbrella or positive type valve stem seals. The original seals were "o-ring" type (not actual o-rings since these seals had a square cross section, not round). The original seals were GM #3835333. I don't think these seals were Viton material. The GM replacement part number as I mentioned in my previous post is GM #10214034. These may be Viton. These "o-ring" type valve stem seals MUST be used in conjunction with stock-type valve spring shields.
        Other types of valve stem seals can be retrofitted to pre-1981 small blocks but they were not originally used.
