57 heater control cables?? - NCRS Discussion Boards
  • Darryl D.
    • February 7, 2017
    • 386
    M 57's heater control cables are too long for this car. I am thinking maybe they are from a passenger car? When you push or pull them they just move the entire cable/housing around. Unless there are supposed to be some type of housing hold down clips to keep these long cables from doing this??
    Any suggestions as to what to do?
  • Garry B.
    • January 1, 1991
    • 667
    Re: 57 heater control cables??
    I don't recall the length of this cable, but maybe someone can measure theirs and report back. I assume you have applied some lube (cable ease) to the internal runner and let it hang for a few days. I seem to recall having the same problem with my '56, but after lubing the cable and I want to say there is a clip at the heater box that holds the housing in place so that it doesn't move and allows the cable to work properly. The EOM cables do seem a little long, but check others to see.
    Garry Barnes 18531
    Garry Barnes #18531
    '67 Lynndale Blue Coupe- National TF, BG
    ​'67 Sunfire Yellow Coupe- 4 Star Bowtie,
    • David S.
      • December 1, 1982
      • 310
      Each cable (hot water valve, fresh air inlet,Defroster )has a clip location to hold the cable end in place for proper operation.
      • Darryl D.
        • February 7, 2017
        • 386
        Any pictures available anywhere?
        • David S.
          • December 1, 1982
          • 310
          Let me know if these work.
          Just like your hood pull cables they need to be clamped for proper operation.
          • Darryl D.
            • February 7, 2017
            • 386
            Thank you!
            • David S.
              • December 1, 1982
              • 310
              Darryl there is also a location on the back of the heater distribution box for that cable
